We Value Your Feedback!
Could you please spare a few minutes to share your thoughts on Cloud Connected vs On-Premise Services. Your feedback can help us shape the future of services.
Learn more about the survey or Click here to Launch the survey
Schneider Electric Services Innovation Team!
Modbus address SD3 28
  • Industrial Automation
  • Solutions for Motor Management
  • Modbus address SD3 28
BJacqz
Commander BJacqz Commander
48
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
12
Bastian_Schmitz
11
Back to Solutions for Motor Management
FlorinG
FlorinG
Cadet
Posted: ‎2025-05-14 12:04 PM
I am facing a misalignment between the parameter address mentioned in the manual SD328A V2.04, 10.2022 and the error that I receive when trying to read the parameter via the PLC.
I am using the PLC M221 for communicating with the driver through Modbus RTU.
I am using the communication block READ_VAR.
In this block, I am setting the parameter address that I want to read from the drive, according to the manual.
I am receiving an error of incorrect address, codes 254 cu 3.
Description of the operation 1:
Parameter description: DCOMStatus
Parameter address: 6916
Error at reading: 254/3, respectively: The value in the request data field is not an authorized value for the slave.
On the other hand,
Descriprion of the operation 2:
Using randomly address 1, I got a value that I cannot identify. Address 1 does not exist in the manual. It seems it is an analogue value, read at minimum value.
See attached files with the respective operations.
I mention:
  • Modbus communication parameters are checked and OK.
  • Using Lexium CT commissioning software I can communicate, I can read and write parameters. But not all the parameters from the manual are accessible in Lexium CT commissioning software, that is confusing.
Please enlighten me to find the error or explain the mismatch between the manual and what I am doing.
  • Drives & Motor Control
Replies 0
This is a heading
