LB1LB03P21 and LD1LB030K , looking for replacements
  • Industrial Automation
  • Solutions for Motor Management
  • LB1LB03P21 and LD1LB030K , looking for replacements
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
BillLee75
BillLee75
Cadet
Posted: ‎2025-04-14 01:53 PM
384
Hello there, not sure if this is in the right location or not.
I have a customer who wants to replace LB1LB03P21 and LD1LB030K, but these are both Discontinued back in 2010/11.
https://www.se.com/au/en/product/LB1LB03P21/protection-module-lb1lb-12-18-a-3-poles-3d-id-270-a/
https://www.se.com/au/en/product/LD1LB030K/dol-contactor-breaker-integral-18-18-a-110-v-ac-60-hz/
Can anyone suggest a replacement for these parts ? Thanks in advance.
  • Drives & Motor Control
Kevin_McDonald
Ensign Kevin_McDonald Ensign
Ensign
Posted: ‎2025-04-16 07:04 AM
Integral starters did not have an exact replacement.  The intention was the Tesys U-Line product would function similar.  This is now known as Tesys Ultra.
Link to the Australia info  - https://www.se.com/au/en/product-range/682-tesys-ultra/#products
