How can the input current to a Variable Speed Drive be less than the output current?
  • Industrial Automation
  • Solutions for Motor Management
  • How can the input current to a Variable Speed Drive be less than the output current?
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
smartatuls
smartatuls Cadet
Cadet
Posted: ‎2022-06-14 09:13 PM
1
2703
The measured VFD input current using power analyzer is 2-3 amps and output current shown on drive display is 10 - 12 amps. The VFD is run at full speed(50Hz).
The output current should be closed to input current at full speed.
Can you please support on this query?
Laureano
Crewman Laureano Crewman
Crewman
Posted: ‎2022-06-30 01:12 AM
You have to specify how are you measuring the current and the characteristics of the instrument.
Please read the following articles.
I let you some links to understand the relation between Input current vs Output current in VFD.
ATV process: ¿Porqué la intensidad de linea es inferior a la intensidad máxima de salida?
https://www.se.com/es/es/faqs/FAQ000133906/
https://www.se.com/us/en/faqs/FA173702/
VFD INPUT CURRENT VS OUTPUT CURRENT
https://voltage-disturbance.com/variable-frequency-drive/vfd-input-current-vs-output-current/
Cómo medir la tensión de salida de un VFD a un motor
https://www.fluke.com/es-es/informacion/blog/motores-accionamientos-bombas-compresores/como-medir-la...
Is input current of VFD smaller than output current?
https://www.variablefrequencydrive.net/is-input-current-of-vfd-smaller-than-output-current.html
VFD current: input side vs. output side
http://www.vfds.org/vfd-current-input-side-vs-output-side-911332.html#:~:text=At%20frequencies%20bel....
