Expected Lifespan for ATV6000 fans
  • Industrial Automation
  • Solutions for Motor Management
  • Expected Lifespan for ATV6000 fans
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Altivar Process (Medium Voltage)
Back to Solutions for Motor Management
sesa92954
Crewman sesa92954 Crewman
Crewman
Posted: ‎2023-11-15 08:34 AM
2
1273
Hello Team!
Does anybody knows what is the Expected Lifespan for ATV6000 fans ?
BR.
@BrownSugar
  • Medium Voltage AC Drives
PriscilaCunha22
Lieutenant JG
Posted: ‎2023-11-17 01:10 AM
1
1263
Hello Wilmar
In the Installation Manual, make sure to check out page 83 for information on Scheduled Servicing. It explains that the fan replacement should be considered every 4 years, depending on environmental conditions.
Keep your system running smoothly with timely maintenance!
ATV6000 Installation Manual
https://www.se.com/us/en/download/document/QGH83258/
PriscilaCunha22
Lieutenant JG
1
1264
Hello Wilmar
BrownSugar
Lieutenant JG BrownSugar Lieutenant JG
Lieutenant JG
Posted: ‎2023-11-17 05:58 AM
In response to PriscilaCunha22
Thank you for the question
