ATV6000 Max HP Range
  • Industrial Automation
  • Solutions for Motor Management
  • ATV6000 Max HP Range
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Altivar Process (Medium Voltage)
Back to Solutions for Motor Management
Hussain.jessani
Hussain.jessani Cadet
Cadet
Posted: ‎2023-11-16 12:24 PM
3
1167
Hello Team,
Is there plans to expand the ATV6000 HP range at 4.16KV for UL approved drives?
Max HP at 4.16KV normal duty for UL approved drive is 3956HP.
Max HP at 4.16KV normal duty for CSA approved drive is 8072HP.
Thanks!
@BrownSugar
  • Drives & Motor Control
PriscilaCunha22
Lieutenant JG
Posted: ‎2023-11-17 12:37 AM
1155
Hello @Hussain.jessani
For UL range we don't have plan, for now, to expand the power.
CSA is following the CE Drives power range.
If you have a business case to sell higher power in UL, please send it to us to discuss.
Thank you
PriscilaCunha22
Lieutenant JG
1156
Thank you
BrownSugar
Lieutenant JG BrownSugar Lieutenant JG
Lieutenant JG
Posted: ‎2023-11-17 05:28 AM
Thank you for the question
Hussain.jessani
Cadet
Posted: ‎2023-11-17 07:34 AM
In response to PriscilaCunha22
Thank you @PriscilaCunha22
