Display
  • Industrial Automation
  • Solutions for Motor Management
  • Display
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
Posted: ‎2022-10-16 04:12 PM . Last Modified: ‎2022-10-16 04:39 PM
1
1104
Display
Hello
I face an issue with AC drive ATV 930
Display only show code instead of parameter and menu name
by mean it show SYS instead of Simply start, dSH instead of Dashboard, DiA instead of Diagnostics
How to revert back to show full name of menu and parameter
Regards and thanks inadvance
BJacqz
Commander
Posted: ‎2022-12-14 02:56 AM
It is possible that language is not in the keypad (for different reason), in this case it is necessary to download again those different languages as you want. in this case, I advise you to follow this instruction : How To Update Language Files on the VW3A1111 Graphic Display Terminal. | Schneider Electric India (s...
I hope it will help you 😉
Bruno Jacqz, Drives training leader
BJacqz
Commander
