Display Wiring
  • Industrial Automation
  • Solutions for Motor Management
  • Display Wiring
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
msidd
Crewman msidd
Crewman
Posted: ‎2022-09-11 10:02 PM
2
1577
Display Wiring
How can we get parameters from Schneider altivar71 display to only on display not inverter.
where I can get wiring diagram of only display access.
oy 24v DC is enough to on display.?
I want to on this device only shown in attach.
BJacqz
Commander
Posted: ‎2022-09-23 07:55 AM
I guess you need to switch on the display, In this case you can supply the control board with 24V, it is just a connection on P24 and 0 connection of the control board.
Bruno Jacqz, Drives training leader
BJacqz
Commander
BhagwanSinghDasila
Crewman BhagwanSinghDasila Crewman
Crewman
Posted: ‎2022-12-17 11:05 AM
Attached Link
https://www.youtube.com/watch?app=desktop&v=kjZi4PAjANU
