Could we use an additional transformer secondary for auxiliaries in ATV6000?
  • Industrial Automation
  • Solutions for Motor Management
  • Could we use an additional transformer secondary for auxiliaries in ATV6000?
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Variable Speed Drives and Soft Starters
Back to Solutions for Motor Management
AitorMartinez1
Crewman AitorMartinez1 Crewman
Crewman
Posted: ‎2022-04-21 08:23 AM . Last Modified: ‎2022-04-21 08:26 AM
2189
Hi there,
I was yesterday in a meeting with the tender team, and a question raised:
There is an opportunity where our customer gives us only one auxiliaries connection for 400 V, but we need 120 V for heating resistors and 230 V for lighting. I think this means that a small transformer should be included inside of one of the cabinets of the drive.
Apart from this, could there be a possibility to generate another secondary from the main converter power transformer and use it for this connection? Which of the options would suppose a higher price increase? Thanks!
  • Design & Build
  • Selection & sizing
BrownSugar
Lieutenant JG BrownSugar Lieutenant JG
Lieutenant JG
Posted: ‎2022-04-22 05:53 AM
Thank you for the question
