BRAKING RESISTOR VALUE
Send InviteCancel
Posted: 2025-03-0508:59 AM
We have install a 3 floor Dumbwaiter and in the controller we use VFD ATV320U15M3C. We Modify Motor by adding rope drum of 8 inches. Now the speed was increased due to drum. we reduced the LSP from 60 hz to 30 Hz to match requirement of 30 ft/min speed. Now while testing with some load in the cabin. it shows OBF (over braking fault). So need to use a dynamic braking resistor. What could be the correct value of resistor to use.
