Altivar ATV12
  • Industrial Automation
  • Solutions for Motor Management
  • Altivar ATV12
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
Zika-Richard11
Ensign Zika-Richard11
Ensign
Posted: ‎2024-12-03 10:06 AM
926
Altivar ATV12
How to control (run stop, freq reference) Altivar ATV12 via remote terminal VW3A1006, VW3A1007 ?
  • Products
Bastian_Schmitz
Admiral
Posted: ‎2024-12-03 11:40 PM
You could find here a FAQ which explains the steps you need.
From factory setting you need to enter conf menu and set FR1=LCC
Then run and stop buttons on remote terminal will work, but display by default will not show frequency reference. Instead motor speed is displayed.
To change freq setpoint on remote terminal, it is necessary to enter rfr menu and select frh. Then freq reference will remain on HMI. Simultaneously, RFR LED diode on HMI will be lit. If the led diode is not lit, rfr menu is not active (and motor speed is shown on HMI).
Bastian_Schmitz
Admiral
Zika-Richard11
Ensign
Posted: ‎2024-12-04 01:12 AM
Thank you @Bastian_Schmitz ! very useful!
