Altivar 71 relay contacts R1 and R2
  • Industrial Automation
  • Solutions for Motor Management
  • Altivar 71 relay contacts R1 and R2
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Altivar Machine
Back to Solutions for Motor Management
temy
temy
Cadet
Posted: ‎2024-09-18 01:45 AM
840
If the R1 assignment is set to 'Ready', will the relay R1 energize if inverter is 'Ready'? or de-energize if inverter is 'Ready'? And I searched the manual, it doesn't seem to have a clear statement on the condition for the inverter to be 'Ready', so on and so forth. Thanks.
LeoLazzaro
Lieutenant
Posted: ‎2024-11-04 04:28 AM
Dear Temy if you set in ATV71 or ATVProcess R1 or R2 as Ready , relay will swtich from 0->1 only when the drive is in RDY(READY)  state , it will be 0 for any other state ( Run, NLP , NST , ACC , DEC ,CLI ,etc) . Thank you
LeoLazzaro
Lieutenant
