Altistart ATS480
  • Industrial Automation
  • Solutions for Motor Management
  • Altistart ATS480
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
Zika-Richard11
Ensign Zika-Richard11
Ensign
Posted: ‎2024-11-07 09:14 AM
784
Altistart ATS480
Which contacts on the Altistart ATS480 can be used to indicate when the motor is running at full speed ?
  • Soft Starters
BJacqz
Commander
Posted: ‎2024-11-12 08:00 AM
R2A and R2C are the contact of the relay which is set for end of starting, those contacts are used for the by pass contactor. Conditions to close this realy are: motor is fed with nominal voltage and the current has decreased to a low value (Around 120% of In).
Bruno Jacqz, Drives training leader
BJacqz
Commander
Zika-Richard11
Ensign
Posted: ‎2024-11-13 03:53 AM
Thank you @BJacqz very helpul!
