ATV630 controlled by a temperature sensor
  • Industrial Automation
  • Solutions for Motor Management
  • ATV630 controlled by a temperature sensor
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
Nick3
Nick3
Cadet
Posted: ‎2023-11-15 08:46 AM
1290
Hi
Bought a ATV630 about a year ago, to control the speed of a fan. (I know probably overkill)
So for the last year I've been adjusting the Hz (fan speed) by hand on the device's it self.
However the plan was to automate this proces.
The idea is when the temp. is at 35°c I need about 10Hz and when we reach 80°c or more, we go to 50Hz.
And off course gradually increase or decrease in between the 2 temps.
I have a PT100 censor.
Long story short 🙂
Can I do this on the ATV it self, or is it better to use a Arduino of Raspberry pi?
Thanks for you're help.
 a not so smart guy, tinkerer, maker
  • Drives & Motor Control
Bastian_Schmitz
Admiral
Posted: ‎2024-09-26 01:37 AM
This is only possible if you use a Converter Temp / 0-10V or 4..20mA. The problem is you could use every Analog Input as source for the acutal value of the intgrated PID. But you could conigure only in that case 0-10V/4..20mA. The Analog input support in general temperature. But the configure for PID did not support this. As additional comment the accuracy of the temp input of ATV Process is for a control function really inaccuracy. (+/-4K).
You could solve this problems if you use a Harmony Converter like
RMPT10BD or a probe with analog output like
BJacqz
Commander
Posted: ‎2024-09-04 06:39 AM
This is a type of regulation you can perform with the ATV process, I advise you to have look on ATV600 programming manual and you will see on PID regulation this possibility. Another way is to look for this video talking on PID regulation with ATV process...
Configuring PID Functions on Altivar Process Drives | Schneider Electric Support (youtube.com)
Bruno Jacqz, Drives training leader
Bastian_Schmitz
Admiral
