ATV320 Drive draws >0.5A current at ideal condition
Send InviteCancel
Posted: 2024-07-2404:25 AM
We have installed 4 nos. ATV320 drives in electrical cabinet & connected to 3ph supply, In ideal condition (All motor at standstill) all 4 nos. drives draw total 1.7A current. If I removed Fuses of one by one then current reduced and becomes 0 after all 4 nos drives fuses removed.
I just want to know why this much current drawn by drives as other compatible drive are not takes this much current ?
