ATV6000 - EAA - Internal PLC
  • Industrial Automation
  • Solutions for Motor Management
  • ATV6000 - EAA - Internal PLC
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Altivar Process (Medium Voltage)
Back to Solutions for Motor Management
ClaudioBarbon
Crewman ClaudioBarbon Crewman
Crewman
Posted: ‎2022-04-19 11:23 AM
2
2389
Hello!
I've a couple of quiestion regarding to update of features in ATV6000:
1- Is it possible to add EAA to the drive (with all the accesories) when it¿s already install in the end user site?
2- Is it possible to customize the internal PLC program to add some new feature (new sensing device with better performance or sensing of new parameters, for example)?
Thanks in advance
  • Design & Build
  • Digitalization
Daniel_Mougin
Ensign Daniel_Mougin Ensign
Ensign
Posted: ‎2022-04-19 10:47 PM
Hello Claudio,
Adding EAA sensors on ATV6000 is a too complex and so too expensive operation to be conducted on site. EAA remains a factory option only.
Modification of the drive PLC program is not allowed to the user.
If this is a suggestion for a change on the offer please contact us internally (Yammer Drives Community)
BR
Daniel
Daniel_Mougin
Ensign
Hello Claudio,
BR
Daniel
BrownSugar
Lieutenant JG BrownSugar Lieutenant JG
Lieutenant JG
Posted: ‎2022-04-22 03:46 AM
Thank you for your question
