Snapshot Reports
Snapshot reports
Send InviteCancel
The Snapshot Reports section allows you to generate, view, and export reports in HTML, CSV (comma-delimited), or PDF format, for the device groups selected.
Element
Description
UPS Runtime
Lists UPS systems, by IP Address, within available UPS Runtime-range categories (for example, <10 minutes).
Device Type Inventory
Lists the number of monitored devices for each device type, by model name.
Battery Age
Lists UPS systems, by IP address, within Battery Age-range categories (for example, 2-3 years).
Environmental Humidity
Lists the % Humidity, by sensor, within Humidity-range categories (for example 40-50).
Environmental Temperature
Lists the Temperature, by sensor, within Temperature-range categories (for example 60-80).
Generate Report
Allows you to choose the device groups you want to include in the report selected.
