"Type" when making a SmartConnector SOAP EWS call
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • "Type" when making a SmartConnector SOAP EWS call
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
CarstenAndersen_SEB-DK
Crewman CarstenAndersen_SEB-DK Crewman
Crewman
Posted: ‎2020-08-26 11:54 PM
1146
Hi
Are trying to map the EBO database in order to find all different elements as, function block programs, time schedules, etc.
I hoped the type could help, but cant find a description of what "type" actually tells?
"Name": "M03_UI-16",
    "Description": "",
    "Type": 0,
    "ParentId": "00/BYGASCHSBO01/SmartConnector/AS1521-001",
    "Id": "00/BYGASCHSBO01/SmartConnector/AS1521-001/M03_UI-16"
Or is there a better way to map the EBO database?
The idea is via machine learning to be able to change for example setpoints found in function block programmes.
henrik_alarmdir
Ensign henrik_alarmdir
Ensign
Posted: ‎2020-08-27 03:29 AM
1140
You will be able to view the database to some extend, but you are right some parts are not documented e.g. type and as well the prefix number in the ID's 00/, 02/, 11/ etc. are not explained.
Crewman
Posted: ‎2020-08-28 01:23 AM
Thanks for clarifying-:)
