I pool a data with DataAdapter.ValueItems.FirstOrDefault(x => x.AlternateId == "xxxx") and the value is not refresh when i update the value with interface
If I execute DataAdapter.CreateDatabaseContext(); before DataAdapter.ValueItems.FirstOrDefault(x => x.AlternateId == "xxxx") then the value result is updated.
Didn't I understand something?
Hi @2clode ,
It looks as though your processor code is long running, in that the DataAdapter is instantiated and then changes are made to your EWS server externally.
You did the right thing. If changes are made in the DataAdapter after it has been instantiated, you need to call the CreateDatabaseContext() to make sure you have the updated data in your DataAdapter.
Best Regards,
-Jeff
