oBIX MQTT integration with EBOv3 & AS-P
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • oBIX MQTT integration with EBOv3 & AS-P
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
sesa188011_brid
Crewman sesa188011_brid Crewman
Crewman
Posted: ‎2019-12-02 08:54 AM
1362
Hi folks,
I'd need to understand how EBOv3 / AS-P can communicate with oBIX or MQTT protocols.
Is Smartconnector the right solution ?
Thanks a lot
Victor
JeffBowman
Sisko
Posted: ‎2019-12-09 06:07 AM
Hi Victor,
Without knowing too much about oBIX, I would say that it is likely that Smart Connector would be able bridge the gap between EBO and oBIX.
That said, a Smart Connector extension for oBIX would need to be developed, but could likely be done pretty easily.
Best Regards,
-Jeff
Posted: ‎2020-02-12 01:31 AM
Hi @sesa188011_brid,
@JeffBowman helped you to solve your problem. Please click on “Accept as Solution” so other members can find the same solution through the search bar.
Thank you!
JeffBowman
Sisko
Hi Victor,
Best Regards,
-Jeff
Thank you!
