comma and point mis-reading from PME EWS through REST API
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • comma and point mis-reading from PME EWS through REST API
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
sesa379286_brid
Ensign sesa379286_brid Ensign
Ensign
Posted: ‎2020-01-23 12:54 AM
1981
Hello, community
I have searched for a similar post but I could not find one. So, I open a new one.
I have an installation of PME with EWS active and SmartConnector installed in order to use the SOAP Rest API.
I can read all the information required:
  • Token
  • Root
  • Container
  • AlarmTypes
  • AlarmEvents
  • Values
  • Trend Logs
My issue is on the format of the values that arrive. In more detail:
Trend Log values arrive as "integer, decimal" which can be ok under circumstances, but Values do not have a decimal part. They are enormous integers (sent as "14355347373" while I would expect 1.435 kWh for example.
Doing some digging with my colleague @Sabrina_Merelli we have seen that reading the data of PME EWS with SOAP UI we have the decimal value but with comma.
We have tried to change the region setting on our pc to be the same but still no proper value reply for us.
All the tests have been done using the swagger and postman.
Do you have any suggestions?
Thank you all
Sotiris
Tags (5)
  • comma
  • ews
  • pme
  • REST API
  • smartconnector
Replies 4
JeffBowman
Sisko
Posted: ‎2020-01-27 08:10 AM
1976
Hi Sotiris,
So you are using the SoapEwsRestProvider to communicate with PME, and the values are coming back without a decimal?
Can you turn on EWS Consume logging in Smart Connector, and set the logging level to Trace? I would like to see what is actually coming back from PME.
Best Regards,
-Jeff
sesa379286_brid
Ensign
Posted: ‎2020-01-28 01:40 AM
Hello Jeff,
we are going to run the tests again and upload the logs of the communication.
Thank you
Sotiris
sesa379286_brid
Ensign
Posted: ‎2020-02-04 01:54 AM
Hello @JeffBowman,
we have activated the EWS consume logging and I attach the information from the logs.
Looking forward to hearing from you
cc: @Sabrina_Merelli
Thank you
Sotiris
Posted: ‎2020-02-07 02:08 AM
Hello @sesa379286_brid,
@JeffBowman helped you to solve your problem. Please click on “Accept as Solution” so other members can find the same solution through the search bar. Thank you!
