i can not add the bundle & permanent license for some ASP & ASB
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • i can not add the bundle & permanent license for some ASP & ASB
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
Shadi_Bawab
Ensign Shadi_Bawab
Ensign
Posted: ‎2025-04-29 05:00 AM
645
i add the ``Entitlement`` in the device administrator (version 5 or 6) to add the license,
then i add the controller and try to add the license, but the ``Entitlement`` does not appear at all as in photo attached in the post
the ``Entitlement`` worked in other controllers so i think there is no problem in it
i format the ASP or ASB by DFU mode and i tried to add the license but same result
This problem appears in controllers version 5 & 6
The problem does not show up when i add the demo license
StephenYang
Admiral StephenYang Admiral
Admiral
Posted: ‎2025-05-05 08:04 AM
@Shadi_Bawab It is possible that the licenses are not compatible with the ASP/ASB if the license is secure boot but the smartX server is not. If you have checked and confirmed that the license is compatible with the devices, I suggest starting a case with your local support team.
