Why would DbContext be disposed during longrunner?
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Why would DbContext be disposed during longrunner?
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
Posted: ‎2018-06-29 12:09 AM
818
A SmartConnector on site is having issues as it isn't updating it's EWS Values. The log is filled with the HTTP Listener receiving XML but then it's unable to update the values due to the Error:
2018-06-20 03:19:26.7367,Error,Processor,<no principal>,Specific Error The operation cannot be completed because the DbContext has been disposed.,
This connector has been running successfully for 6 months and now the log is being filled with this error even after a restart, it's version 2.3.117 of the Framework.
Any ideas of the cause?
sesa180908_brid
Commander
Posted: ‎2018-06-29 05:31 AM
All DB access in SmartConnector is based on Entity Framework.  EF caches extensively and it is possible for your context to have "stale" data if you keep it open for extended periods of time.  Create the DbContext when you need it, read/write as needed, and then dispose of it.  That is the recommended usage pattern. This is true even if you are in an ILongRunningProcessor.
