VS2015/2017 myget installation problem
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • VS2015/2017 myget installation problem
JeffBowman
Sisko JeffBowman Sisko
164
ardak
34
sesa180908_brid
34
mike_meirovitz
Commander mike_meirovitz
21
Back to SmartConnector Forum
henrik_alarmdir
Ensign henrik_alarmdir
Ensign
Posted: ‎2018-06-29 04:13 AM
693
Hi
I'm trying to get my VS environment setup for developing an extension, however I cannot get the smartconnector package installed in VS.
I have added the package as described in the Developer Guide 5.3 and updated/clicked OK.
The when I open the samples solution and try to build the CustomSoapProvider VS starts to download the package, then it present me with a login dialog to access myget.org - I didn't have an account so I created one on their web, I'm able to logon there but this account doesn't work when fetching the package.
So... my question is, want have I missed here?
Same problem in both 2017 and 2015.
JeffBowman
Sisko
Posted: ‎2018-06-29 06:13 AM
Hi Henrik,
With the pre-authenticated link, it should work. Did you ever receive the invite for the Smart Connector NuGet packages? If not, I can send it to you if you send me your email. Also, from your screenshots, I see your user name 'hhaumann', so I have added access to that user in MyGet. You should get a notification about this (if this works, then I don't need your email address). Once you can confirm you have access to the feed, go into the 'Feed Details' in MyGet.org and copy your pre-authenticated URL into your NuGet package source.
Let me know if this works!
-Jeff
JeffBowman
Sisko
Hi Henrik,
-Jeff
