Why is Mongoose.Service Taking so Much Memory?
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Why is Mongoose.Service Taking so Much Memory?
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
Lydia
Lieutenant | EcoXpert Master Lydia Lieutenant | EcoXpert Master
Posted: ‎2021-07-14 05:51 AM
1426
I was noticing a strange issue when testing my company's processor. When the processor starts, Mongoose.Service uses a decently small amount of memory. Maybe ~85 MB. As the processor continues going though on/off cycles using a schedule, the amount of memory Mongoose.Service uses increases without appearing to bottleneck.
At first, I assumed that the issue was occurring due to issues with my company's processor. I changed the processor to try to decrease the amount of memory needed and reduce the possibility for a memory leak to occur. It did not help. The amount of memory used by Mongoose.Service continued to creep up without appearing to bottleneck.
On a hunch, I ended the processor and took it off a schedule. I then added Schneider's Null Processor, a processor whose only task is to sleep for 5 seconds before ending, and added it to a 30 second schedule. I then restarted SmartConnectorService. Mongoose.Service, as expected, started with using 88.3 MB. I let the Null Processor run overnight. Currently, the Null Processor ran 2,539 times and uses 2,375 MB of memory, roughly 10x the memory used with my company's processor running in production at a facility with >3,000 points and which uses caching to keep track of memory.
Why is Mongoose.Service using so much memory, and what can I do to fix this problem?
I have attached three files: a log file, a screen shot of Task Manager, and a screen shot of Resource Manager. Would also send the dump file, but it's too large.
SmartConnector: 2.4.25
Mongoose.Service Photos & Log.zip
Tags (8)
  • leak
  • memory
  • mongoose
  • null
  • processor
  • server
  • сервер
ardak
Posted: ‎2021-07-14 06:15 AM
Hi Lydia,
Thank you for the thorough steps to recreate your issue. I'll start a null processor in the way you described and to see if I can recreate it locally and I'll come back to you.
BR
Armend
ardak
Posted: ‎2021-07-14 11:27 PM
Hi again,
I left a null processor running overnight and couldn't reproduce your issue. Could you try upgrading to the latest smartconnector and see if your problem persists?
I'd love to analyze your dump file if possible, I'll send my email to you in a private message.
BR
Armend
