1. When we try modifying a string EBO value via REST APIs and the new value is alpha-numeric (i.e.: "hello"), the value that is written to the EBO is null ("") instead of "hello".
In the SmartConnector log we can see this line:
Debug,RestServe,admin,Values,UpdateValue,C836B7E024DE4ABA9A27FD351A63C4D7,Request,{"Id":"01%2FServer 1%2FMyValues%2FString1","NewValue":null},
If we write a numeric value such as "111111", then the value is written to the EBO as expected.
Debug,RestServe,admin,Values,UpdateValue,C3C8E312A6564746B98AFA10BE4AC63D,Request,{"Id":"01%2FServer 1%2FMyValues%2FString1","NewValue":"111111"},
2. We have a similar problem with Time Stamp EBO values. When the new value we try write is "12/7/2021 2:00:00 PM",
the value is not written to the EBO and the SmartConnector log file shows that the new value is "07". See below.
Debug,RestServe,admin,Values,UpdateValue,E3426514679043659671937880F7EB79,Request,{"Id":"01%2FServer 1%2FMyValues%2FTime Stamp Value1","NewValue":"07"},
Any idea what is causing this problem?
Thank you.
Mike
Hi Mike,
For a string to be parsed correctly, it needs to be in quotation marks, e.g.
"hello world".
This is because strings need to be encased for them to be valid JSON. A number does not.
Regarding the Timestamp, I would use the format Smartconnector uses, like this example from the subscription endpoint on Swagger:
"ExpiresOn": "2021-07-13T05:11:46.148Z"
Working with dates is a pain.
Hope this helps,
Armend
I did the same using the Swagger and the results are the same. If I try to assign the string value "999999" or "111111" it works fine, but if I try an alphanumeric string such as "Hello world", the value becomes "". See the attached file with a screen capture of the Swagger.
I appreciate your answer.
Mike
Hi Mike,
"hello world".
Hope this helps,
Armend
Hi Armend,
Thank you for your answer. In the Swagger it works nice!
Mike
