Which SmartConnector version is required for EBO 1.9.2.45?
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Re: Which SmartConnector version is required for EBO 1.9.2.45?
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
  • Intelligent Devices Forum
Back to SmartConnector Forum
Evren
Lt. Commander Evren Lt. Commander
Posted: ‎2020-03-29 07:25 PM
2093
Have an existing site in which we are trying to add a smart connector for 3rd party integration. SmartConnector v2.4 shall be compatible however I could not find any reference in the installation manual.
Is there a benefit upgrading the site EBO version to 1.9.4.29 from the SC application perspective?
JeffBowman
Sisko
Posted: ‎2020-04-02 06:35 AM
1
2068
Hi!
You should be fine with any version of Smart Connector with 1.9.2.45. The issues with Smart Connector/EBO were in earlier versions of EBO/SC :).
Best Regards,
-Jeff
Replies 5
Richard_M
Lieutenant JG Richard_M Lieutenant JG
Posted: ‎2020-04-01 04:43 PM
2079
Wouldn't "any" version of Smart Connector work? The Smart Connector is only presenting an EWS server to EBO. So maybe is it comes down to the extension itself.
Evren
Posted: ‎2020-04-01 05:00 PM
2077
Hi Richard; Yes that is what I believe with "any version" compatibility - but I have not bench tested so worth asking the question.
With earlier versions of EBO; there were some glitches with SC so also worthwhile checking the compatibility and fixed issues.
Richard_M
Posted: ‎2020-04-01 09:12 PM
2074
Fair enough. I've used 2.2.130 with 1.9.2.45 and above (up to 3.1.x). I've never gone the other way round (latest Smart Conn with older EBO versions)
JeffBowman
Sisko
1
2069
Hi!
Best Regards,
-Jeff
SteveGregory
Commander SteveGregory Commander
Posted: ‎2020-05-27 04:55 AM
I had issues reading Extended logs that came from BACnet points. I believe we needed EBO 1.9.3+ to resolve it (but i may be wrong, it might have been 1.9.2+).
