Websocket for longrunningprocessor
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Websocket for longrunningprocessor
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
ahmet191
Ensign ahmet191
Ensign
Posted: ‎2022-11-09 05:45 AM
1577
I did a websocket search in the forum but nothing came up.
I need to listen to the websocket broadcasting from an API. Erwin-Vd-Zwart had helped before and sent me the code sample I wrote below. It is very useful for my standard updates. I have no problem with it. But I need an uninterrupted use to listen to websocket. If it is in the loop, the socket will be closed and opened. I'll paste my code below. Is there anyone who can help with this?
Erwins Code;
#region Execute_Subclass - Override
protected override IEnumerable<Prompt> Execute_Subclass()
for (;;)
CheckCancellationToken();
// Perform here your class to do the actual request
Task.Delay(FeedbackInterval * 1000).Wait();
#endregion
My Code;
for(; ; )
using (WebSocket ws = new WebSocket("ws://192.168.1.106:5555/event"))
ws.Connect();
ws.OnMessage += (sender, e) =>
DataAdapter.ModifyValueItemValue("deviceName_1003", "success", EwsValueStateEnum.Good); //for testing, not important
//Task.Delay(5000).Wait();
#endregion
Erwin-vd-Zwart
Janeway
Posted: ‎2022-11-10 01:39 AM
1559
You can do that by adding a task like "connect" and then execute a connect.wait(), the for(;;) loop will now wait until the task 'connect' is completed, inside the task connect i added a loop to listen to the websocket messages and this will happen until the connection is lost, in this scenario the task never completes and keeps looping anmd listening to the messages until the connection is lost, then the task completes and loop will be executed again initiating a new connect etcetera..
See this sample where all is working as you want.
BR,
Erwin
WebSocket.zip
Erwin-vd-Zwart
Janeway
1560
BR,
Erwin
WebSocket.zip
ahmet191
Ensign ahmet191
Ensign
Posted: ‎2022-11-10 01:45 AM
1554
Exactly what i need and more. Thank you for your answer
Erwin-vd-Zwart
Janeway
Posted: ‎2022-11-10 01:48 AM
On line 84 you have the string 'content' and that might be converted  to JSON (i assume your WS is publishing JSON) and from there you can execute actions to write to the EWS server.
Please test intensive as the code is still rudimentery and not used in production yet.
BR,
Erwin
