After upgrading to V2.2.108, I modified the test program with highlighted. No test program was found on Test Explorer.
Clicked on Run All and got the following message:
------ Discover test started ------
NUnit VS Adapter 2.0.0.0 discovering tests is started
Attempt to load assembly with unsupported test framework in C:\SBO-MobileView-Integration\Sources\SmartConnector.Extension.MobileView\SmartConnector.Extension.MobileView.Test\bin\Debug\SmartConnector.Extension.MobileView.Test.dll
NUnit VS Adapter 2.0.0.0 discovering test is finished
========== Discover test finished: 0 found (0:00:01.223) ==========
Is there any thing I missed?
Thanks!
It seems that you are using NUnit 3.x attributes so I assume that you updated to that NuGet.
You can't "run" the test assy with NUnit 3 the way you used to do with NUnit 2.
You should review Section 6 of the SmartConnector Developers Guide for your options. What's outlined there is how to do things with NUnit 3
Yes, you are right. I reset it back to NUnit 2.6.4 and it works now.
Thanks!
