Is there any API to update the smartconnector configuration parameter value by code at runtime? Or should I update the database Parameters table.
My smartconnector integration application has a parameter ‘StartMode’whose default value is ‘ColdStart’, I want to update it to ‘WarmStart’ after
first run.
Neeraj,
There is no API specifically to accomplish that but the ConfigurationId is available as a property of your Processor class. So, you could do something like this:
You would need to add a reference to Mongoose.Configuration first and then you could write something like this:
using (var db = MongooseObjectFactory.Current.GetInstance<IProcessConfigurationDataSource>())
var config = db.ProcessConfigurations.FirstOrDefault(x => x.Id == ConfigurationId);
var parameter = config.Parameters.FirstOrDefault(x => x.Name == "PROPERTY_NAME_HERE");
if (parameter != null)
parameter.Value = "WarmStart";
db.Save();
A Parameter maps to a scalar value property. My code snippet assumes that "PROPERTY_NAME_HERE" is the name property on your processor. If the property is a property of a reference type attached to your Processor, it would be a little more complicated but still doable.
M
Neeraj,
db.Save();
M
Thanks Mark ! It works for me.
