SmartConnector use problem!?
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • SmartConnector use problem!?
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
TomeLu
Commander | EcoXpert Master TomeLu Commander | EcoXpert Master
Posted: ‎2021-11-07 11:48 PM
1941
I use SmartConnector for the first time
I currently want to try the SmartConnector function
Just got a new account and installed the software
Download the certification on the SmartConnector webpage
Upload to local computer
Always say that my approval has expired! ?
I want to ask what is the reason?
TomeLu
Posted: ‎2021-11-09 06:12 PM
1910
Hi , @ardak
Thank you for your help
I try to reinstall the SmartConnect program
At present, the certification has been uploaded successfully, and other functions can be operated
If you still have any questions after trying, I will ask again
thanks
Replies 6
ardak
Posted: ‎2021-11-08 12:48 AM
5
1937
----> Download the certification on the SmartConnector webpage
Please elaborate on the steps taken during this step, this is probably where the issue lies.
BR
Armend
TomeLu
Posted: ‎2021-11-08 05:11 PM
1934
Hi @ardak
I use Runtime 2.4 (Developer) as a demonstration, here are my steps
1. Log in to the local Smart Connecrtor
2. Copy "Machine Fingerprint"
3. Log in to the SmartConnector server
4. Click Runtime 2.4 (Developer)
5. Paste "machine fingerprint"
6. Successfully downloaded Smart Connector 2.4 Core (Developer).lic
7. Upload to the local Smart Connector
8. Show that my certificate has expired
Is there a problem with my steps?
thanks for your help
ardak
Posted: ‎2021-11-08 10:19 PM
3
1927
Ok!
Could you please go to the portal -> setup -> service settings and set the logging level to trace, try to upload the license again and attach the logs?
They are located in %programdata%\Smartconnector\Logs
BR
Armend
TomeLu
Posted: ‎2021-11-09 01:29 AM
Hi @ardak
I followed the method you said
SmartConnector has been set up
Also successfully found the Logs record
The following is the recorded content
2021-11-09 17:22:31.2881,Error,Service,<no principal>,Padding is invalid and cannot be removed.
at System.Security.Cryptography.RijndaelManagedTransform.DecryptData(Byte[] inputBuffer, Int32 inputOffset, Int32 inputCount, Byte[]& outputBuffer, Int32 outputOffset, PaddingMode paddingMode, Boolean fLast)
at System.Security.Cryptography.RijndaelManagedTransform.TransformFinalBlock(Byte[] inputBuffer, Int32 inputOffset, Int32 inputCount)
at SxL.Common.Crypto.Decrypt(String value, String keyValue, String initializationVector)
at Mongoose.Common.Data.ExtensionMethods.Decrypt(IEncryptable encryptable, String encryptionKey)
at Mongoose.Service.Data.MongooseDbContext.OnObjectMaterialized(Object sender, ObjectMaterializedEventArgs e)
at System.Data.Entity.Core.Objects.ObjectContext.OnObjectMaterialized(Object entity)
at System.Data.Entity.Core.Common.Internal.Materialization.Shaper.RaiseMaterializedEvents()
at System.Data.Entity.Core.Common.Internal.Materialization.Shaper`1.StopMaterializingElement()
at System.Data.Entity.Core.Common.Internal.Materialization.Shaper`1.SimpleEnumerator.MoveNext()
at System.Linq.Enumerable.FirstOrDefault[TSource](IEnumerable`1 source)
at Mongoose.Service.Licensing.AntiRollbackDateTime.get_UtcNow()
,["Current WindowsIdentity is NT AUTHORITY\\SYSTEM"],
2021-11-09 17:22:31.2881,Trace,Service,<no principal>,Validating framework license,
2021-11-09 17:22:36.3064,Error,Service,<no principal>,Padding is invalid and cannot be removed.
2021-11-09 17:22:36.3064,Trace,Service,<no principal>,Validating framework license,
2021-11-09 17:22:41.3347,Error,Service,<no principal>,Padding is invalid and cannot be removed.
2021-11-09 17:22:41.3347,Trace,Service,<no principal>,Validating framework license,
2021-11-09 17:22:46.3610,Error,Service,<no principal>,Padding is invalid and cannot be removed.
2021-11-09 17:22:46.3610,Trace,Service,<no principal>,Validating framework license,
2021-11-09 17:22:51.3812,Error,Service,<no principal>,Padding is invalid and cannot be removed.
2021-11-09 17:22:51.3812,Trace,Service,<no principal>,Validating framework license,
2021-11-09 17:22:54.5054,Error,Service,admin,Padding is invalid and cannot be removed.
2021-11-09 17:22:54.6094,Error,Service,admin,Padding is invalid and cannot be removed.
2021-11-09 17:22:54.6094,Debug,Utility,admin,MayNotContinue : Your license has expired. Please contact your distributor/vendor to renew the license.,
2021-11-09 17:22:56.4015,Error,Service,<no principal>,Padding is invalid and cannot be removed.
2021-11-09 17:22:56.4015,Trace,Service,<no principal>,Validating framework license,未命名.jpg
TomeLu
1911
Hi , @ardak
thanks
ardak
Posted: ‎2021-11-09 09:21 PM
I'm glad you could make it work!
BR
Armend
