SmartConnector integrated SQL database
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • SmartConnector integrated SQL database
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
TomeLu
Commander | EcoXpert Master TomeLu Commander | EcoXpert Master
Posted: ‎2023-02-05 05:41 PM
2834
hello experts
Has anyone tried to integrate SQL database toEBO through SmartConnector?
Is there a procedure for sharing relevant information?
Thanks in advance
SteveGregory
Commander SteveGregory Commander
Commander
Posted: ‎2023-02-06 12:46 PM
2
2814
There is a generic SQL SmartConnector you can get that will allow you to configure a query and will create the EWS points to represent the result. https://exchange.se.com/api/navigation-service/shop/apps/39687/smart-connector---microsoft-sql-datab...
Replies 7
SteveGregory
Commander
2
2815
TomeLu
Posted: ‎2023-02-12 04:15 PM
Hi @SteveGregory
thanks for your reply
I am currently trying to write a program to let PostgreSQL return to EBO through MQTT,
But I'll try your way
Erwin-vd-Zwart
Janeway
Posted: ‎2023-02-12 10:25 PM
2764
Can you elaborate on what you are trying to achieve?
TomeLu
Posted: ‎2023-02-14 01:52 AM
Hi @Erwin-vd-Zwart
My purpose is to write machine learning scripts in EBO,
So I import the historical data into the EBO script program
make the program more complete
Erwin-vd-Zwart
Janeway
Posted: ‎2023-02-14 04:03 AM . Last Modified: ‎2023-02-14 04:04 AM
1
2734
Well you could create a SC that acts as a REST GW between Postgresql and script so you can fetch data from the DB with a web request, however there are already API's available that can run as a services on a windows machine, like https://postgrest.org/ that exposes an API on the DB without having to write a SC.
The downside is that most responses are JSON and parsing JSON via script is a trivial task.
If you realy want to create AI inside EBO i would look into the option to connect EBO via MQTT to Azure IoT Hub and write your AI in Azure, but that is just a suggestion how to build something future proof..
TomeLu
Posted: ‎2023-02-14 05:17 PM
Hi @Erwin-vd-Zwart
If possible, I want to use Azure IoT Hub, after all, there are many extended functions on it
But customers remain concerned about information security and cost in the cloud
Therefore, I thought of this way to deal with local data
thanks for your comments
huynhngochoi
Lieutenant | EcoXpert Master huynhngochoi Lieutenant | EcoXpert Master
Posted: ‎2023-02-27 05:58 PM
Hi Sir,
I have followed this link but I can't see "ISC.SqlReaderExtension.dll" in "C:\Program Files (x86)\Schneider
Electric\SmartConnector".
