Smart Connector Microsoft SQL Database Integration
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Smart Connector Microsoft SQL Database Integration
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Smart Connector
Back to SmartConnector Forum
huynhngochoi
Lieutenant | EcoXpert Master huynhngochoi Lieutenant | EcoXpert Master
Posted: ‎2023-03-01 04:02 AM
3919
Hi everybody,
I am having a problem, I have configured it according to the instruction file (attached file). However, I am not getting any variables on the EBO side.
Has anyone encountered this error?
  • Thumbnail of Smart Connector
    Smart Connector
View products (1)
PiotrJakubczyk
Sisko PiotrJakubczyk Sisko
Sisko
Posted: ‎2023-03-01 04:31 AM . Last Modified: ‎2023-03-01 04:32 AM
3
3914
Hi @huynhngochoi
Did you try to go to System/Hardware/EcoStruxure Web Services and right click and "Host EWS Object"?
https://ecostruxure-building-help.se.com/bms/Topics/show.castle?id=8766&locale=en-US&productversion=...
Replies 4
PiotrJakubczyk
Sisko
3
3915
Hi @huynhngochoi
huynhngochoi
Posted: ‎2023-03-01 04:40 AM
3913
Hi @PiotrJakubczyk ,
I did as you said but I still don't get the values I wanted
PiotrJakubczyk
Sisko
Posted: ‎2023-03-03 03:42 AM . Last Modified: ‎2023-03-03 03:45 AM
3871
@huynhngochoi
There were also other problems? What was your solution? Probably you need to go into smartconnector Setup and configure Logging
SmartConnector provides the ability to configure different logging levels and different log categories. While the logging features can be very helpful to debug any issues, there are some log level and category combinations that could represent a security vulnerability.
Specifically, the use of “All”, “Debug”, or “Trace” log levels along with logging for the Portal and API will cause unencrypted processor configuration values to be stored in the log file. Thus, it is recommended to not operate at “All” or “Debug” log levels unless necessary to trace a problem.
All SmartConnector logs are written to the “%PROGRAMDATA%\SmartConnector\Logs”
huynhngochoi
Posted: ‎2023-03-03 05:04 PM
I don't see anything other problem
First I delete all Processor & EWS Servers, then add them again and Host EWS Object as you said.
