Hi
Does anybody know of a smartconnector that supports IEC 61850 or IEC 60870-5-104?
Basically this has nothing to do with SmartConnector itself, it’s a framework running in C# that makes it possible to communicate with EBO through EWS and 3th party Ip interface(s).
The communication to the 3th party needs to be written in C# or you can use a library that already exists by reference it to your project.
Some quick search on google shows there are already libraries that support the protocol you are looking for, for example libIEC61850, an open-source library.
You could try this..
