SmartConnector failed to start after restarting the computer - "Class not registered"
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • SmartConnector failed to start after restarting the computer - "Class not registered"
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
mike_meirovitz
Commander mike_meirovitz
Commander
Posted: ‎2020-10-27 11:36 PM
921
We are using SmartConnector 2.4.17. After restarting our server we got the following error:
2020-10-28 08:27:24.5174,Error,Service,<no principal>,Class not registered
at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo)
at System.Management.ManagementScope.InitializeGuts(Object o)
at System.Management.ManagementScope.Initialize()
at System.Management.ManagementObject.Initialize(Boolean getObject)
at System.Management.ManagementClass.GetInstances(EnumerationOptions options)
at SxL.Licensing.MachineThumbprinter.GetActiveMacAddresses()
at SxL.Licensing.MachineThumbprinter.AllPossibleThumbprints()
at Mongoose.Service.Licensing.LicenseEnforcer.ValidateLicense()
at Mongoose.Service.Mongoose.HasValidFrameworkLicense()
2020-10-28 08:28:01.5316,Error,Service,<no principal>,Error while building type Mongoose.Service.LoggerFilterProvider. See the inner exception for details
1.) new LoggerFilterProvider()
2.) Mongoose.Service.LoggerFilterProvider
3.) Instance of SxL.Common.ILoggerFilterProvider (Mongoose.Service.LoggerFilterProvider)
4.) Container.GetInstance(SxL.Common.ILoggerFilterProvider)
An exception occurred while initializing the database. See the InnerException for details.
An exception has been raised that is likely due to a transient failure. If you are connecting to a SQL Azure database consider using SqlAzureExecutionStrategy.
The underlying provider failed on Open.
The client was unable to establish a connection because of an error during connection initialization process before login. Possible causes include the following: the client tried to connect to an unsupported version of SQL Server; the server was too busy to accept new connections; or there was a resource limitation (insufficient memory or maximum allowed connections) on the server. (provider: Shared Memory Provider, error: 0 - No process is on the other end of the pipe.)
After starting the SmartConnector service manually, it started with no problems.
Any idea?
Thank you.
Mike
JeffBowman
Sisko
Posted: ‎2020-10-30 09:36 AM
915
Hi Michael,
From the errors, it looks like there was an issue connecting to the Smart Connector database.
Was this a one time thing, or do you see this occurring often?
Best Regards,
-Jeff
mike_meirovitz
Commander
Posted: ‎2020-10-30 11:22 PM
Hi Jeff,
I don't recall if it happened before. It doesn't happen often.
Thanks.
Mike
