Our SmartConnector extension (EWS server) processor starts even when the "Run on Start" property is set to "False"
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Our SmartConnector extension (EWS server) processor starts even when the "Run on Start" property is set to "False"
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
mike_meirovitz
Commander mike_meirovitz
Commander
Posted: ‎2020-10-27 07:11 AM
1200
Our SmartConnector extension (EWS server) processor starts even when the "Run on Start" property is set to "False".
The SmartConnector log file for the current date is not created. However, our SmartConnector's extension log files shows that it is running.
Any idea why?
Thank you.
Michael
Replies 4
JeffBowman
Sisko
Posted: ‎2020-10-28 01:02 PM
1197
Hi Michael,
Is your processor set to run on a schedule?
If the processor is offline for a bit, then the scheduled run would start right away on startup.
Best Regards,
-Jeff
mike_meirovitz
Commander
Posted: ‎2020-10-29 06:24 AM
1194
Hi Jeff,
Runs on Schedule = False.
Thanks.
Mike
JeffBowman
Sisko
Posted: ‎2020-10-30 09:24 AM
1189
Hi Michael,
Can you please post a screenshot of what exactly is running on start that is not supposed to? And then also a screenshot of the properties of this?
Best Regards,
-Jeff
mike_meirovitz
Commander
Posted: ‎2020-10-30 11:20 PM
Hi Jeff,
See below. The EBO-OPC Client Update Processor should run at start. After restarting the server, it is running. You can see the stop button.
Thanks.
Mike
