We Value Your Feedback!
Smart Connector Web Portal not showing our .dll when on "Add New" processor page.
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Re: Smart Connector Web Portal not showing our .dll when on "Add New" processor page.
JeffBowman
Sisko JeffBowman Sisko
164
ardak
34
sesa180908_brid
34
mike_meirovitz
Commander mike_meirovitz
21
Back to SmartConnector Forum
danielglassford
danielglassford Schneider Alumni (Retired)
Posted: ‎2022-02-04 01:17 PM
1359
We have developed a smart connector processor and copied over the .dll into the Smart Connector folder under program files x86. When we run Smart Connector v2.4.40 we can see the processor in the web portal, but under v2.5.49 we cannot see the .dll processor in the smart connector web poral.
Is there a way to target a specific smart connector version AND above so that a processors we make can always be loaded into each new version of the smart connector without need to update the NuGet packages and reupdate? We think this is the cause that the .dll that we are generating is only compatible with smart connector v2.4.40 and below but not any newer versions.
We want to know what the standards are to help avoid this issue in the future.
  • Thumbnail of Smart Connector
    Smart Connector
View products (1)
Replies 3
ardak
Posted: ‎2022-02-04 10:20 PM
2
1353
Hi Daniel!
We work to be compatible between versions, and as far as I'm aware, there should be know issues running a .dll built in 2.4.40 in 2.5.4.9.
Are you getting any error messages in the log?
BR
Armend
danielglassford
Posted: ‎2022-02-07 03:26 AM
1347
Hi!
We do get some error messages in the log when I enable "portal" logging with logging level of "All", but I get these regardless of if the .dll is in the smart connector folder or not... But here it is below. We have two versions of the same processor and one adds and the other does not so we are looking into what the differences are. You are right the older version actually adds and its pointing to an old .net target and mongoose.* versions. So its likely something we are doing. But if you have any suggestions let me know. Thanks!
Kindly,
Daniel Glassford
2022-02-04 08:46:49.7110,Debug,Portal,admin,ProcessorConfigurations,Get,A823A2AEA56D4A5A8F177DEEDDCCDFE6,Request,Root.ProcessorConfigurations.ProcessorConfigurationsView,
2022-02-04 08:46:49.7110,Trace,Service,admin,Validating framework license,
2022-02-04 08:46:49.8481,Debug,Service,admin,No Flexera license found for smartconnector.service, status was UnknownError. Continuing to check for native Smart Connector license.,No valid client license available.
(Error -5: No such feature exists.),
2022-02-04 08:46:49.9771,Debug,Portal,admin,ProcessorConfigurations,Get,A823A2AEA56D4A5A8F177DEEDDCCDFE6,Response,{},
2022-02-04 08:46:49.9771,Info,Portal,admin,ProcessorConfigurations,Get,ET=266 mSec,
2022-02-04 08:46:50.9544,Trace,WorkerManager,<no principal>,InMemoryCache Cleanup Complete,ET=0 mSec,
2022-02-04 08:46:50.9544,Trace,WorkerManager,<no principal>,EwsServerSubscription Cleanup Complete,ET=0 mSec,
2022-02-04 08:46:50.9584,Trace,WorkerManager,<no principal>,WorkerManager service maintenance complete,ET=4 mSec,
2022-02-04 08:46:51.1827,Debug,Portal,admin,AddProcessorConfiguration,Get,6A6DDDA4EECC4A29983BD9BCC97CC670,Request,Mongoose.Service.Portal.Root.AddBindingInformationView.cshtml,
2022-02-04 08:46:51.1827,Trace,Service,admin,Validating framework license,
2022-02-04 08:46:51.3511,Debug,Service,admin,No Flexera license found for smartconnector.service, status was UnknownError. Continuing to check for native Smart Connector license.,No valid client license available.
2022-02-04 08:46:52.1365,Debug,Portal,admin,ProcessorConfigurations,GetPage,2BBE27B73BCD417BA165B92077B338EE,Request,{"Page":1,"SearchTerms":"undefined"},
2022-02-04 08:46:52.1365,Debug,Portal,admin,ProcessorConfigurations,GetPage,2BBE27B73BCD417BA165B92077B338EE,Response,{},
2022-02-04 08:46:52.1365,Info,Portal,admin,ProcessorConfigurations,GetPage,ET=2 mSec,
2022-02-04 08:46:52.3626,Error,Portal,admin,Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information.
at System.Reflection.RuntimeModule.GetTypes(RuntimeModule module)
at System.Reflection.RuntimeModule.GetTypes()
at System.Reflection.Assembly.GetTypes()
at Mongoose.Service.Portal.Root.AddBindingInformationBaseController`2.GetClassList(AssemblyListItemModel assemblyInfo)
at Mongoose.Service.Portal.Root.AddBindingInformationBaseController`2.GetAssemblyList(String rootFolder)
,["Error attempting to load assembly C:\\Program Files (x86)\\Schneider Electric\\SmartConnector\\SE.WorkStation.Otm.dll. Loader Exception(s): \r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'Google.ProtocolBuffers, Version=2.4.1.521, Culture=neutral, PublicKeyToken=55f7125234beb589' or one of its dependencies. The system cannot find the file specified.\r\nCould not load file or assembly 'SE.WorkStation.Communication.WBL, Version=3.2.1.537, Culture=neutral, PublicKeyToken=null' or one of its dependencies. A strongly-named assembly is required. (Exception from HRESULT: 0x80131044)\r\nCould not load file or assembly 'SE.WorkStation.Communication.WBL, Version=3.2.1.537, Culture=neutral, PublicKeyToken=null' or one of its dependencies. A strongly-named assembly is required. (Exception from HRESULT: 0x80131044)\r\nCould not load file or assembly 'dotNetRDF, Version=2.1.1.0, Culture=neutral, PublicKeyToken=6055ffe4c97cc780' or one of its dependencies. The system cannot find the file specified.\r\n"],
2022-02-04 08:46:52.3706,Debug,Portal,admin,AddProcessorConfiguration,Get,6A6DDDA4EECC4A29983BD9BCC97CC670,Response,{},
2022-02-04 08:46:52.3706,Info,Portal,admin,AddProcessorConfiguration,Get,ET=1188 mSec,
ardak
Posted: ‎2022-02-07 05:18 AM
Hi Daniel,
Hmm, interesting, thanks for bringing that up. I agree, the portal errors shown can be ignored in your case.
If I understand you correctly you have two versions of the same extension, and one works on both 2.4.40 and 2.5.4, the other one only works on 2.4.40? Or does one not work in either version?
Armend
This is a heading
