Security Expert SmartConnector EWS State Offline State Online
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Security Expert SmartConnector EWS State Offline State Online
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
PiotrJakubczyk
Sisko PiotrJakubczyk Sisko
Sisko
Posted: ‎2022-04-05 08:10 AM . Last Modified: ‎2022-04-05 08:22 AM
1589
Hello. We have problem with Security Expert SmartConnector We are reading 110 doors from ESE to EBO and all 107 doors are ok but 3 last doors Status is offline. Points that are not read are Status and Position. We have run discovery processor and nothing has changed.
EBO version is 3.2.3.59
SmartConnector: 2.4.38
ESE: 4.3.285.42
Anyone have idea how to troubleshoot this (if this is ESE or SmartConnector problem)?
We try to restart everything, run discovery processor and checked logs. Don't know how check smart connector extension version? (but we suppose it is 1.0.18.5)
Nothing interesting in SmartConnector logs:
05T12:42:58,
2022-04-05 14:43:02.2005,Info,WorkerThread,<no principal>,Security Expert Alarm Update Processor,Started,
2022-04-05 14:43:02.2942,Info,WorkerThread,<no principal>,Security Expert Alarm Update Processor,Ended successfully,
2022-04-05 14:43:02.2942,Info,WorkerThread,<no principal>,Security Expert Alarm Update Processor,Next run will be at 2022-04-05T12:43:03,
2022-04-05 14:43:07.4384,Info,WorkerThread,<no principal>,Security Expert Alarm Update Processor,Started,
2022-04-05 14:43:07.5452,Info,WorkerThread,<no principal>,Security Expert Alarm Update Processor,Ended successfully,
2022-04-05 14:43:07.5452,Info,WorkerThread,<no principal>,Security Expert Alarm Update Processor,Next run will be at 2022-04-05T12:43:08,
2022-04-05 14:43:12.6844,Info,WorkerThread,<no principal>,Security Expert Alarm Update Processor,Started,
2022-04-05 14:43:12.7752,Info,WorkerThread,<no principal>,Security Expert Alarm Update Processor,Ended successfully,
2022-04-05 14:43:12.7752,Info,WorkerThread,<no principal>,Security Expert Alarm Update Processor,Next run will be at 2022-04-05T12:43:13,
2022-04-05 14:43:17.9054,Info,WorkerThread,<no principal>,Security Expert Alarm Update Processor,Started,
2022-04-05 14:43:17.9982,Info,WorkerThread,<no principal>,Security Expert Alarm Update Processor,Ended successfully,
2022-04-05 14:43:17.9982,Info,WorkerThread,<no principal>,Security Expert Alarm Update Processor,Next run will be at 2022-04-05T12:43:19,
2022-04-05 14:43:23.1375,Info,WorkerThread,<no principal>,Security Expert Alarm Update Processor,Started,
2022-04-05 14:43:23.3050,Info,WorkerThread,<no principal>,Security Expert Alarm Update Processor,Ended successfully,
2022-04-05 14:43:23.3070,Info,WorkerThread,<no principal>,Security Expert Alarm Update Processor,Next run will be at 2022-04-05T12:43:24,
2022-04-05 14:43:28.4472,Info,WorkerThread,<no principal>,Security Expert Alarm Update Processor,Started,
2022-04-05 14:43:28.6577,Info,WorkerThread,<no principal>,Security Expert Alarm Update Processor,Ended successfully,
2022-04-05 14:43:28.6577,Info,WorkerThread,<no principal>,Security Expert Alarm Update Processor,Next run will be at 2022-04-05T12:43:29,
ardak
Posted: ‎2022-04-05 10:48 PM
The first step would be to look at the extension. I have contacted you privately on teams with contacts.
BR
Armend
PiotrJakubczyk
Sisko
Posted: ‎2022-04-19 12:49 AM
Issue solved
Probably issue was related to manually created doors. Related case number 90129390.
Issue was not corrected in 4.3.308.52. Manual database correction needed.
