SboRestProvider Get/Alarms not working
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • SboRestProvider Get/Alarms not working
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
SteveGregory
Commander SteveGregory Commander
Commander
Posted: ‎2019-11-13 02:15 AM
1440
I am having issues trying to use the Get/Alarms with with EBO 3.0.2.33 and SmartConnector 2.4.22. The SBO REST provider returns a HTTP 500 error "Code=InvalidData..." and the SOAP REST provider returns "Buld Retrieve for alarm is not allowed".
Other functions of the web service are working fine and this has worked fine on previous versions. Can anyone suggest anything? Screen shots attached.
JeffBowman
Sisko
Posted: ‎2019-11-15 06:43 AM
1429
Hi Steve,
Just to finish up here, per our emails, it seems you actually wanted to use the /AlarmEvents endpoint and not the /Alarms endpoint. Is this all working correctly now?
Best Regards,
-Jeff
SteveGregory
Commander
Posted: ‎2019-11-18 09:07 PM
1425
Yes it was actually the alarm events that I was after and that is working fine, thank you for pointing that out. However, should the GetAlarms still return something when using the CSP endpoint?
JeffBowman
Sisko
Posted: ‎2019-11-19 08:34 AM
Hi Steve,
In theory it should! I will need to look if there were any changes in CSP in 3.x that would cause this to fail when searching. It seems between releases they break the search mechanism, so I wouldn't doubt it, if it stopped working.
Best Regards,
-Jeff
Replies 5
JeffBowman
Sisko
Posted: ‎2019-11-13 10:15 AM
1435
Hi Steve,
You are correct about the SOAP provider, it simply doesn't support getting alarm items in bulk.
However, the SBO provider should in theory work.. However, because the SBO Provider uses EBO's CSP protocol behind the scenes, it is very possible they changed something in the protocol, that would need to be addressed in the REST Provider. Would it be possible for you you to turn on the Csp Client logging in Smart Connector and tell me what it shows when you send this request when using the SBO provider (also set logging level to trace).
Best Regards,
-Jeff
SteveGregory
Commander
Posted: ‎2019-11-13 05:28 PM
1432
See attached log file.
2019-11-14.log
JeffBowman
Sisko
1430
Hi Steve,
Best Regards,
-Jeff
SteveGregory
Commander
1426
JeffBowman
Sisko
Hi Steve,
Best Regards,
-Jeff
