We Value Your Feedback!
Could you please spare a few minutes to share your thoughts on Cloud Connected vs On-Premise Services. Your feedback can help us shape the future of services.
Learn more about the survey or Click here to Launch the survey
Schneider Electric Services Innovation Team!
GET /AlarmEvents - long alarm list is returned for the same alarm ID
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • GET /AlarmEvents - long alarm list is returned for the same alarm ID
JeffBowman
Sisko JeffBowman Sisko
164
ardak
34
sesa180908_brid
34
mike_meirovitz
Commander mike_meirovitz
21
Back to SmartConnector Forum
mike_meirovitz
Commander
Posted: ‎2019-04-10 12:33 AM
859
I am using the Swagger to test the GET /AlarmEvents API for one alarm ID. I see that the response shows the alarm history for this alarm ID. See below.
My questions:
1. Is there a way to get a response just for the last alarm state and not the entire history?
2. When this alarm history is being cleared?
Thank you.
Michael
    "AlarmId": "02/Server 1/Values/LightsAllFloors Change of State Alarm",
    "Acknowledgeable": 1,
    "OccurredOn": "2019-04-09T16:21:18Z",
    "LastTransitionedOn": "2019-04-09T17:27:39Z",
    "Message": "Building lighting is OFF",
    "Priority": 100,
    "State": 1,
    "Type": "",
    "AlarmSourceName": "LightsAllFloors Change of State Alarm",
    "Id": "/Server 1|/Server 1/Values/LightsAllFloors Change of State Alarm|e90c40a6-a4ac-4206-9bb5-fc78954b9149"
    "Acknowledgeable": 0,
    "LastTransitionedOn": "2019-04-10T06:42:21Z",
    "Message": "Building lighting is ON",
    "Priority": 100,
    "State": 0,
    "Type": "",
    "Id": "/Server 1|/Server 1/Values/LightsAllFloors Change of State Alarm|644090ed-84d6-4c4c-ba08-2361f8c9fc5b"
    "OccurredOn": "2019-04-10T06:42:46Z",
    "LastTransitionedOn": "2019-04-10T06:42:46Z",
    "Priority": 100,
    "State": 1,
    "Type": "",
    "Id": "/Server 1|/Server 1/Values/LightsAllFloors Change of State Alarm|86351495-0b14-4805-b5dd-0b0aeed0474a"
    "LastTransitionedOn": "2019-04-10T06:49:40Z",
    "Priority": 100,
    "State": 0,
    "Type": "",
    "Id": "/Server 1|/Server 1/Values/LightsAllFloors Change of State Alarm|909163d4-3aed-497f-93e9-9672e8352cb0"
    "OccurredOn": "2019-04-10T06:50:13Z",
    "LastTransitionedOn": "2019-04-10T06:50:13Z",
    "Priority": 100,
    "State": 1,
    "Type": "",
    "Id": "/Server 1|/Server 1/Values/LightsAllFloors Change of State Alarm|474a6def-9703-498f-afd4-91dd71233000"
    "LastTransitionedOn": "2019-04-10T06:50:44Z",
    "Priority": 100,
    "State": 0,
    "Type": "",
    "Id": "/Server 1|/Server 1/Values/LightsAllFloors Change of State Alarm|bc9118fd-64b5-4dba-9565-5032c1ba2111"
JeffBowman
Sisko
Posted: ‎2019-08-06 12:53 PM
2
847
Hi Firdous,
This has already been taken care of via email and can be closed.
-Jeff
Replies 4
Posted: ‎2019-08-06 08:56 AM
850
Hi community members,
Can you help @mike_meirovitz  on this topic please?
Thank you!
JeffBowman
Sisko
2
848
Hi Firdous,
-Jeff
RoarHauge
Lieutenant JG RoarHauge Lieutenant JG
Lieutenant JG
Posted: ‎2019-11-12 11:04 PM
828
Hi Jeff,
I got the same problem on a site which uses this for alarm surveilance.
Could I get the solution?
Speciallly to question number 2: (When this alarm history is being cleared?)
I scripted a restart of SmartConnector at midnight which clearard the oldest events upto that point.
But any alarm change is being added to the list as long as GET/AlarmEvents is triggered.
This happens every 30 seconds.
The customer now has to look for LastTransitionedOn for each AlarmID to get current status.
I have tested with Smart Connector 2.4.10, 2.4.21 and 2.4.22 together with EcoStruxure Building Operation 1.9.3, 2.0.2 and 3.0.2
/Roar
JeffBowman
Sisko
Posted: ‎2019-11-13 10:23 AM
Hi Roar,
I will say your fix is likely to add a filter to your web service request with LastTransitionedTime as your key filter. See below for the two query parameters required. Basically you will need to set OnOrAfter to the last known transition time of your previous request, and TransitionedBefore to the current time (UTC). That will get you only updated alarm events. However, because the alarm events endpoint returns all historic states as well with each response, it is possible that even using this filter, you can retrieve two events from the same alarm. In that case, you must filter on the most recent LastTransitionedTime from each AlarmId.
Best Regards,
-Jeff
This is a heading
