Sample SmartConnector Restful API Client
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Sample SmartConnector Restful API Client
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
sesa237670_brid
sesa237670_brid Schneider Alumni (Retired)
Posted: ‎2018-03-20 10:00 AM
1478
Hi Jeff,
I downloaded the latest sample from Github 'GitHub - BuildingsLabs/SmartConnectorSamples: Sample projects for SmartConnector ' and able to build the project. I copied 'Ews.RestExtensions.Client' and 'CustomRestExtension' assemblies in Smartconnector folder on my machine. However, when I do 'Add Endpoint Configuration' on smartconnector portal I don't get the option to add these new client application Endpoint.
Please advise if I am missing some step ? I am trying to add the sample smartconnector restful API client and test it. So, I can extend it to add my own webmethods.
Thanks!
Neeraj Tomar
  • sample smartconnector restful api client
JeffBowman
Sisko
Posted: ‎2018-03-20 10:20 AM
1394
Hi Neeraj,
What version of Smart Connector do you have installed? The version of Smart Connector installed, must be the same version as the NuGet packages used to build the project.
I think what you might need to do, is first install the latest Smart Connector NuGet packages into the sample project (manage NuGet packages..).
-Jeff
JeffBowman
Sisko
1395
Hi Neeraj,
-Jeff
sesa237670_brid
Posted: ‎2018-03-20 10:44 AM
Hi Jeff,
I have the latest version 'SmartConnector 2.3.117' installed on my machine. Following your response, I updated the NuGet Package for samples. Copy over the updated assembles in smartconnector folder. Still the same. Please advise.
Thanks!
Neeraj Tomar
