How to retrieve Alarm Comment, Cause, Action & Checklist data
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • How to retrieve Alarm Comment, Cause, Action & Checklist data
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
sesa116095_brid
Ensign sesa116095_brid Ensign
Ensign
Posted: ‎2018-03-22 07:39 AM
844
Hello!
We're looking for a advice how to retrieve the alarm comment, cause note, action note & checklist data for alarms.
Ellis
JeffBowman
Sisko
Posted: ‎2018-03-22 08:10 AM
Hi Ellis,
I am assuming you want to get this data from an alarm object, and not the alarm event itself.
It is possible to get the Alarm comment(s) via EWS. Below is a method I wrote that does this give a list of EWS Alarm Item IDs.
public List<AugmentedAlarmItem> AugmentAlarmItems(List<AlarmItemType> alarmItems)
    Logger.LogDebug(LogCategory.Processor, this.Name, $"Getting alarm messages for {alarmItems.Count} alarms..");
    var returnList = new List<AugmentedAlarmItem>();
    var alarmItemsTracker = alarmItems.ToList();
    while (alarmItemsTracker.Count > 0)
        var thisRequest = alarmItemsTracker.Take(250).ToList();
        List<string> propertyIds = new List<string>();
        foreach (var alarm in thisRequest)
            propertyIds.Add($"1{alarm.Id.Remove(0, 1)}/AlarmMessage");
            propertyIds.Add($"1{alarm.Id.Remove(0, 1)}/ResetMessage");
            propertyIds.Add($"1{alarm.Id.Remove(0, 1)}/LowLimitMessage");
            propertyIds.Add($"1{alarm.Id.Remove(0, 1)}/HighLimitMessage");
        var values = _ewsClient.GetValues(propertyIds.ToArray());
            var alarmMessage = values.GetValuesItems.ToList().FirstOrDefault(a => a.Id == $"1{alarm.Id.Remove(0, 1)}/AlarmMessage")?.Value;
            var resetMessage = values.GetValuesItems.ToList().FirstOrDefault(a => a.Id == $"1{alarm.Id.Remove(0, 1)}/ResetMessage")?.Value;
            var highLimitMessage = values.GetValuesItems.ToList().FirstOrDefault(a => a.Id == $"1{alarm.Id.Remove(0, 1)}/HighLimitMessage")?.Value;
            var lowLimitMessage = values.GetValuesItems.ToList().FirstOrDefault(a => a.Id == $"1{alarm.Id.Remove(0, 1)}/LowLimitMessage")?.Value;
            returnList.Add(new AugmentedAlarmItem
                Id = alarm.Id,
                Description = alarm.Description,
                MonitoredValueId = alarm.ValueItemId,
                AlarmMessage = !string.IsNullOrEmpty(alarmMessage) ? alarmMessage : $"{highLimitMessage}{(!string.IsNullOrEmpty(highLimitMessage) && !string.IsNullOrEmpty(lowLimitMessage) ? " ; " : string.Empty)}{lowLimitMessage}",
                ResetMessage = resetMessage,
        alarmItemsTracker.RemoveRange(0, thisRequest.Count());
    return returnList;
As far as the cause note, action note and checklist. This is a whole other question, one of which I have never done before. Your best bet might be either to try and find a way to use the WorkStation SDK to get this information, or the new Mongoose.Csp Nuget Package directly (NOT the new SboEwsRestProvider which uses this behind the scenes). Both of these ways will require a much more in-depth understanding about how EBO works behind the scenes, but it should be possible.
-Jeff
