SNMP Extension Smart connector
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • SNMP Extension Smart connector
JeffBowman
Sisko JeffBowman Sisko
164
ardak
34
sesa180908_brid
34
mike_meirovitz
Commander mike_meirovitz
21
Back to SmartConnector Forum
Raja_SAWANT
Lieutenant JG Raja_SAWANT Lieutenant JG
Lieutenant JG
Posted: ‎2020-03-18 08:46 AM
5
2277
Hello Team,
We are installing Smart Connector software for testing SNMP communication from 3rd party to Automation Server-Premium.
Schneider Laptop Lenova make T470. Windows 10 Professional 64 bit OS.
SQL Server 2016 Express Service Pack 2 installed successfully prior to installing Smart Connector.
Installed Smart Connector Software (SmartConnector-2.4.23.exe) on my Laptop successfully.
License of Smart Connector framework develop and SNMP extension successfully installed.
We are unable to start SNMP Processor configuration server .
Pls find attached the error log file.
Can someone support here to start the SNMP Processor as we are unable to proceed further on EBO EWS.
Thanks in advance.
Appreciate your time and efforts.
Rajesh G. SAWANT
Replies 5
Posted: ‎2020-03-18 08:52 AM
2273
I would start at the top and work you're way down the log. First error is that is says the license isn't the correct one for the SNMP Extension.  Fix that then check again.
Raja_SAWANT
Lieutenant JG
Posted: ‎2020-03-18 10:57 PM
2266
Hello James,
Thanks for quick revert. But the SNMPExtension license file downloaded from the Marketplace https://www.smartconnectorserver.com/Account/Login?ReturnUrl=%2Fmarketplace
The validity is also for 30 days. Expiring on 17th April 2020.
Kindly suggest if this is the correct license file ? If not which is the correct one ?? and where do i get it from ???
Rajesh G. SAWANT
JessieSu
Lieutenant JessieSu Lieutenant
Lieutenant
Posted: ‎2021-08-25 08:16 PM
2164
@Raja_SAWANT
Hi Rajesh,
Did you succeed finally?
Thanks!
Jessie
Raja_SAWANT
Lieutenant JG
Posted: ‎2022-04-13 09:56 PM
Yes. Jessie. We did. Thanks Rajesh
GENJUA
Lt. Commander GENJUA
Lt. Commander
Posted: ‎2023-09-08 05:35 AM
@Raja_SAWANT  i am facing the same problem.
Please advise how did you resolved the license issue?
BR
Genjua
