SBO REST Provider cannot read objects in an AS
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • SBO REST Provider cannot read objects in an AS
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
SteveGregory
Commander SteveGregory Commander
Commander
Posted: ‎2018-08-15 01:15 AM
1740
Is there a way to read points from within a function block program, via the SmartConnector SboEwsRest Provider? I can't seem to read the points, even though they are public.
Also, when using Get/Values to get all values that match a filter criteria, only values on the ES seem to come up in the results. Should / Does the interface also search the automation servers?
JeffBowman
Sisko
Posted: ‎2018-08-16 12:47 PM
1
1720
Hi Steve,
Smart Connector version 2.4.7 was released with the fix for the issue with the GET /Values and /Trends only returning objects from the ES. See the release notes for more details. Smart Connector Release Notes.pdf
-Jeff
Replies 7
JeffBowman
Sisko
Posted: ‎2018-08-15 01:05 PM
2
1720
Hi Steve,
I took a look and it seems we were never searching in subservers, and only the parent. I will be releasing a new version of Smart Connector in the next day or so that has the fix for this.
As far as seeing properties of Menta programs, I honestly have no idea if this works, or if the SboEwsRestProvider was designed for this to work either. I will take a look and get back you on that in the next day or two.
-Jeff
Benji
Administrator Benji Administrator
Posted: ‎2018-08-15 09:21 PM
Just a note. Points in Menta are actually properties and not objects. Pretty sure it’s different for Function Block.
Benji
Posted: ‎2018-08-16 02:39 AM
1720
Nope, also in Function Block points are actually properties, not objects.
SteveGregory
Commander
Posted: ‎2018-08-16 07:20 AM
I guess that would explain why they don’t have an ‘object type’ property. The question is then, can the SboEwsRestProvider read properties of a function block program?
JeffBowman
Sisko
1
1721
Hi Steve,
-Jeff
SteveGregory
Commander
Posted: ‎2018-08-21 09:49 PM
Will download and try version 2.4.7. Thanks Jeff.
SteveGregory
Commander
Posted: ‎2018-08-31 04:06 AM
Version 2.4.7 fixed my issue. The get/values and get/trends now returns values from the automation servers also. Thanks Jeff
