REST Web Service Gets Slower Over Time
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • REST Web Service Gets Slower Over Time
JeffBowman
Sisko JeffBowman Sisko
164
ardak
34
sesa180908_brid
34
mike_meirovitz
Commander mike_meirovitz
21
Back to SmartConnector Forum
SteveGregory
Commander SteveGregory Commander
Commander
Posted: ‎2018-02-28 11:09 PM
904
We have a site where we are serving all the log data to a third party using the RESTfull Web Service Endpoint in SmartConnector. Initially we are seeing response times of 100-300ms, but as the client goes through the list of trend samples that it is polling, the time starts to increase. We are seeing it grow to 15 - 20 seconds per poll.
When we restart the SmartConnector service, it is quick again, but over time starts to slow down.
The SmartConnector is installed on the ES Server machine and is only reading extended log data. The client reads 1000 logs every hour. Each request is for three hours worth of data.
The server CPU and RAM remain low at all times, but we cannot establish the reason for the degradation in performance.
2018-03-01.log.zip
JeffBowman
Sisko
Posted: ‎2018-03-05 10:25 AM
Hi Steven,
A new version of Smart Connector 2.3 has been released, which addresses the issue you were seeing. Please see version 2.3.117.
-Jeff
Replies 4
JeffBowman
Sisko
Posted: ‎2018-03-01 05:44 AM
2
846
Hi Steven,
Thank you for reporting this problem!
I have taken a look at your logs, and it seems that the request to SBO is pretty consistent in terms of speed, and the issue seems to be somewhere in the SmartConnector REST stack. I will dig into this and see what I find.
-Jeff
SteveGregory
Commander
Posted: ‎2018-03-01 02:22 PM
846
Hi Jeff, If you need more detail in the logs, just let me know. I can provide you with remote access to the site if you want to take a closer look yourself.
JeffBowman
Sisko
Posted: ‎2018-03-02 05:40 AM
Thank you Steven,
I will let you know if I need anymore information for sure!
-Jeff
JeffBowman
Sisko
Hi Steven,
-Jeff
