Password Reset
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Password Reset
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
JessieSu
Lieutenant JessieSu Lieutenant
Lieutenant
Posted: ‎2018-06-13 11:07 PM
1288
Password Reset
Does anyone know how to reset admin's password of SmartConnector? The project administrator changed the password and then forgot it......
I think the password should be reset after reinstall the SmartConnector, but is that means we will config it again? Is there any other way to get the password or reset it?
Thank you!
Best Regards
Jessie
Adam_Summers
Lt. Commander Adam_Summers Lt. Commander
Lt. Commander
Posted: ‎2018-06-14 01:01 AM
1
1248
If you are still able to access the SmartConnector database you can reset from there. You will need to do a new installation on another machine, once completed if you then go into the user table you can see the encrypted password for the admin user with the credential which you would have set after your first login. You can copy and paste that credential into the site database and you should be able to login with that password.
Adam_Summers
Lt. Commander
1
1249
JessieSu
Lieutenant
Posted: ‎2018-06-14 02:25 AM
Hi Adam,
Thank you and I will try it.
Best Regards
Jessie
