POST to acknowledge an alarm unsuccessful
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • POST to acknowledge an alarm unsuccessful
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
Posted: ‎2020-08-01 09:26 PM
1150
Hi everyone,
I was wondering if it's possible to acknowledge alarms through the REST api? I've tried to acknowledge an alarm that has State value 1 and Acknowledgable value 1, the alarm ID is double encoded, and the url looks like this   https://some.url.com:8083/AlarmEvents/%252FServer%2B1%257C%252FServer%2B1%252FQLD%2BHealth%252FLocat...
I first tried the POST request in Postman, it returned status code 204 and an empty response body, but when I fetch the alarm events again, it didn't show up in the event list. I've also tried this request using a java library, and it returned HTTP code 500 internal server error.
Does any one know what's causing this issue? Or is there another recommended method to acknowledge alarms outside EBO? Thank you!
KarimHussain
Commander KarimHussain Commander
Commander
Posted: ‎2020-08-02 10:48 PM
It sounds like you acknowledged it successfully. Code 2XX means the request was recieved by the API and the reason why it is not in the list anymore might be because it was in "Reset state" mening Green color in the alarm list. When you acknowledge, it transitions into "Normal state" and normally you don't show alarms with Normal state in the alarms list because that would show alll the alarm points in the system.
Could you check the history events for that specific alarm point and see if it was acknowledged? Just right-click the alarm point and select to see events.
KarimHussain
Commander
