I tried to get the point description from BACNet and Infinet alarms with the following code:
public bool ProcessAlarms(EwsClient clientObj)
responseObjByCat = clientObj.GetAlarmEvents();
alarmEvents = responseObjByCat.GetAlarmEventsAlarmEvents;
foreach (AlarmEventsType alarmEvent in alarmEvents.AlarmEvent)
if (!string.IsNullOrEmpty(alarmEvent.Type))
string idX = alarmEvent.SourceID;
string[] idsa = new string[] { idX };
var items1 = clientObj.GetItems(idsa);
if (items1.GetItemsItems.AlarmItems.Count() != 0)
alarmArchiverInfo.PointPath = items1.GetItemsItems.AlarmItems[0].ValueItemId;
idsa = new string[] { alarmArchiverInfo.PointPath };
var pointValue = clientObj.GetItems(idsa);
alarmArchiverInfo.PointValue = "";
if (pointValue.GetItemsItems.ValueItems.LongLength != 0)
alarmArchiverInfo.PointValue = pointValue.GetItemsItems.ValueItems[0].Value;
alarmArchiverInfo.PointDescription = pointValue.GetItemsItems.ValueItems[0].Description;
For regular ES alarms, it works fine. But it returns empty value on BACNet and Infinet alarms. (see attached)
How can I fix the problem?
I am using SmartConnector V2.4.23 and EBO V3.1.2.29.
Thanks!
Juh
Hi Juh,
I was able to reproduce this as well using SOAPUI. So this is not a Smart Connector specific issue and is likely a bug in EBO.
I would recommend working on opening a bug vs EBO about this.
Best Regards,
-Jeff
Hi Juh,
Best Regards,
-Jeff
