PME Installation Error on Windows 11 Home
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • PME Installation Error on Windows 11 Home
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
EcoStruxure™ Power Monitoring Expert
Back to SmartConnector Forum
chama07
chama07
Cadet
Posted: ‎2025-03-03 11:57 PM
918
I am trying to install Power Monitoring Expert (PME) on my Windows 11 Home PC, but I keep encountering the following error message during installation:
"Your operating system does not meet the minimum requirements for this product. Please validate that your Operating system version, architecture, edition, and service pack meet the documented requirement. The installation will now exit."
System Details:
  • Operating System: Windows 11 Home
  • SQL Server Version 2022
  • Other Relevant Software Installed .NET Framework
Steps I Have Tried:
  1. Checked system requirements for PME but couldn’t find clear details about Windows 11 Home compatibility.
  2. Ensured that IIS and .NET Framework are installed.
  3. Tried running the installer in compatibility mode.
  4. Attempted reinstalling SQL Server to see if that helps, but no success.
My Questions:
  1. Does PME support Windows 11 Home, or do I need to upgrade to Windows 11 Pro?
  2. Are there any specific workarounds to bypass this issue?
  3. Which exact system requirements must be met for PME to install successfully?
Any guidance from the community would be greatly appreciated.
Thank you!
  • Thumbnail of EcoStruxure™ Power Monitoring Expert
View products (1)
Tags (3)
  • pme
  • power monitoring expert
p_dejarmy_encos
Lieutenant p_dejarmy_encos
Lieutenant
Posted: ‎2025-03-05 06:07 PM
PME doesn't support Windows Home. The following OS are supported:
For further system requirements, I recommend that you check out the PME 2024 IT Guide: Power Monitoring Expert 2024 IT Guide | Schneider Electric
Best regards,
