One Time Read a File
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • One Time Read a File
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
Kanber
Commander | EcoXpert Master Kanber Commander | EcoXpert Master
Posted: ‎2019-06-13 06:38 AM
2353
I have one text file for read tag names and I don't what to lost time every time to read the text file. I want to read only when smart connector service is start.
JeffBowman
Sisko
Posted: ‎2019-06-13 08:10 AM
Hi Kanber,
I think it goes back to my first response, and what @Adam_Summers  was mentioning about using the In memory cache. The in memory cache is cleared whenever Smart Connector restarts. So this will accomplish what you are looking for. (e.g. not reading the file every time)
var cachedFileRead = Cache.RetrieveItem<FileReadResultType>("TheCacheItemKey");
if (cachedFileRead == null)
    var readFileResults = ReadTheFile();
    Cache.AddOrUpdateItem(readFileResults, "TheCacheItemKey");
    _tagList= readFileResults;
else
    _tagList= cachedFileRead;
You can add code similar to the above in your Execute_Subclass method. Most likely, this code will be at the start of your Execute_Subclass method. _tagList is a private field of your class where which is whatever type your tag list is. You can then use _tagList from anywhere else in the class to access it.
-Jeff
Replies 9
Adam_Summers
Lt. Commander Adam_Summers Lt. Commander
Lt. Commander
Posted: ‎2019-06-13 06:47 AM
Not sure if I fully understand the question but if you want to read something (configuration) once on service start and not on each processor cycle you have 2 options.
1) Read and store in memory cache - this stores for the runtime of the service (or until the expiry datetime you set)
2) Read and store in processor values - this survices a reset but could still be updated on first run.
For me option 1 is best, it will perform better and provide you a simple way to check if the value you want (config data) exists in cache - if not update it, if it does return fast and use it. A lazy loading approach.
JeffBowman
Sisko
Posted: ‎2019-06-13 06:50 AM . Last Modified: ‎2019-06-13 06:50 AM
2348
Hi Kanber,
The best way to do this, is probably to cache the data the first time the processor runs.
    TagList = readFileResults;
else
    TagList = cachedFileRead;
You could also create a processor, whos job in life is to read the file and add it to the cache, then run that processor on start.
Best Regards,
-Jeff
Kanber
Posted: ‎2019-06-13 07:11 AM
2345
Hi Jeff,
But I  don't know which code I need to add these. as you know we have;
- Execute_Subclass
- Discover
- SmartConnectorEwsServerSettings
which are them working only once which are working every schedule time? I look doucment but I can't solve.
JeffBowman
Sisko
Posted: ‎2019-06-13 07:26 AM
2340
Hi Kanber,
All code in your processors executes out of the Execute_Subclass method. This check is likely something that you do at the start of that.
-Jeff
Kanber
Posted: ‎2019-06-13 07:45 AM
2338
Ok I will try.
which method working with schedule time? I mean when we add dll file on smart connector and edit schedule lets say 10 min. every 10 min which method is fisrt running.
JeffBowman
Sisko
Posted: ‎2019-06-13 07:56 AM
2
2336
Hi Kanber,
The Execute_Subclass method is the entrypoint of the processor, so if you setup a schedule, this method will ALWAYS be run first. Your code should start from in that.
In order to setup a schedule you just need to create a Configuration Schedule with setting similar to the below:
And then set your processor to run on a schedule.a
And finally set the schedule on the processor:
Best Regards,
-Jeff
Kanber
Posted: ‎2019-06-13 08:06 AM
2334
that mean these is not what I am looking for.
I want to one method which will run when windows is open and smart connector service start to running and first time when dll was called. then it will read text file once and on scheduled timed it will not read file again and again.
JeffBowman
Sisko
Hi Kanber,
else
-Jeff
Posted: ‎2019-08-02 05:27 AM . Last Modified: ‎2019-08-02 05:28 AM
Hi @Kanber,
Did you find the solution on the replies above?
If yes, please click on "Accept as Solution" at the bottom right corner of the answer which solved your problem.
You can also thanks the members who tried to help you by liking their comments!
