Error,Service,<no principal>,The underlying provider failed on Open
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Error,Service,<no principal>,The underlying provider failed on Open
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
mike_meirovitz
Commander mike_meirovitz
Commander
Posted: ‎2019-07-13 11:10 PM
894
Our customer received the following error and the SmartConnector failed to start.
Error,Service,<no principal>,The underlying provider failed on Open.
Login failed for user 'sa'. Reason: Server is in single user mode. Only one administrator can connect at this time.
Any idea what is the problem?
Thank you.
Mike
JeffBowman
Sisko
Posted: ‎2019-07-15 06:11 AM
889
Hi Michael,
The error seems to be that your SQL  instance is in Single User Mode, and there seems to be another admin user connected somehow. I would recommend using google to figure out how to change this.
Best Regards,
-Jeff
JeffBowman
Sisko
890
Hi Michael,
Best Regards,
-Jeff
mike_meirovitz
Commander
Posted: ‎2019-07-15 06:48 AM
Thank you Jeff!
Mike
